1999 Ford F150 mirror switch
59,000 MILES • 6 CYL • 2WD • AUTOMATIC
LIMABLUE
The mirror switch quit working on out adjustment on both sides, so it's apparently a switch problem since all other directional movements are normal. Question - how do I get the switch out of the armrest to check or replace it?
Feb 23, 2009 at 7:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
The switch should just pop out with a little force. If not, you will need to remove the door panel by removing any hidden screws/bolts and then popping it out of the plastic snap locks. Then you should be able to pop the switch out and disconnect the electrical connections.
Thanks for using 2CarPros.com!
Feb 25, 2009 at 12:59 PM
LIMABLUE
I figured I'd try to pop it out first, but what I wanted to know is the proper way to make the repair. If Ford says the switch pops out, OK, but if they say the door panel has to come off, I need to know the location of the "hidden" fasteners, rather than me trying to pry it off looking for them.
Feb 27, 2009 at 12:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Door panel removal instructions are below. REMOVAL: Disconnect the negative battery cable. Remove the front door sail panel. Remove the inside door handle finish panel. If equipped with power windows, remove the window regulator switch plate. If equipped with manual windows, remove the window regulator handle by separating the handle cover from the handle. Remove the handle retaining screw and remove the window regulator handle and the spacer. WARNING Do not pull directly outward on the front door trim panel, as damage may occur. Remove the door panel retaining clips. Remove the door panel retaining screws. Lift and remove the front door trim panel. If equipped, twist the courtesy lamp bulb socket one quarter turn and remove the socket from the front door trim panel.
https://images.2carpros.com/forum/automotive_pictures/261618_0900c152801e5b1b_1.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_0900c152801e5b1c_1.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_0900c152801e5b1d_1.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_0900c152801e5b20_1.jpg
(((Removing the door pillar trim by carefully puling it outward to release the trim clips)))
https://images.2carpros.com/forum/automotive_pictures/261618_0900c152801e5b22_1.jpg
(((Removing the door panel by carefully lifting the panel upward to release the retaining clips)))
https://images.2carpros.com/forum/automotive_pictures/261618_0900c152801e5b25_1.jpg
INSTALLATION: The installation is the reverse of the removal. Thanks for using 2CarPros.com!
Feb 27, 2009 at 6:08 AM
