Is it possible the fluid is leaking inside the diaphragm of the power booster? I can find no leaks in the lines or at the wheel cylinders.
Feb 1, 2010 at 8:42 PM
DOCFIXIT
✓ASE Certified Mechanic
Master cylinder leaking into booster is common. Most times you can feel wetness under cyl. on booster.
Feb 2, 2010 at 11:57 AM
