Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Brakes
Wheel Cylinder
Leak
1999 Ford F150 Losing Fluid-no visible leaks
1999 FORD F-150
115,000 MILES • V8 • 4WD • AUTOMATIC
SAVAGENEWTON
MEMBER
1 POST
Is it possible the fluid is leaking inside the diaphragm of the power booster? I can find no leaks in the lines or at the wheel cylinders.
Feb 1, 2010 at 12:42 PM
DOCFIXIT
Experienced Mechanic
Master cylinder leaking into booster is common. Most times you can feel wetness under cyl. on booster.
Feb 2, 2010 at 3:57 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
