1999 Ford F-150 jerking at speeds over35mph
ONELEVIT
  • 1999 FORD F-150
  • V8
  • 4WD
  • 13,000 MILES
Thought it was spark plugs but cant find any
Wednesday, February 3rd, 2010 AT 10:03 PM
Inspect and test all the following listed below:
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Cap and rotor
Note:If it doesn't apply disregard.
Thursday, February 4th, 2010 AT 4:54 AM
