1999 Ford F150 interior/cargo light stays on
88,000 MILES • 6 CYL • 2WD • MANUAL
ED23600
My interior and cargo light stays on after engine is shut off and door is shut. Is there a switch in the door latch, and if so, how do I get access to repair ?
Mar 27, 2009 at 10:59 AM
JAMES W.
  • 2,394 POSTS
It's a real common problem with Fords. The switches for the lights are attached to the inside of the door latches. Get yourself a can of spray silicone and liberally spray down the latches from the outside and work the doors a few times. That'll take care of it. You'll probably have to do this often.
Apr 1, 2009 at 3:25 PM
