1999 Ford F150 IDLE PROBLEMS
100,112 MILES • 6 CYL • 2WD • MANUAL
DIRTYTRUCK
THE IDLE IS REMAINING HIGH EVEN WHEN CLUTH IS ENGAGED. THE ONLY TIME THAT IT IDLES CORRECTLY IS A FULL STOP. IT IS NOT THE THROTTLE CONTROL SENSOR,I REPLACED THAT AND IT IS STILL THE SAME
Feb 23, 2008 at 6:03 AM
BLACKOP555
  • 10,386 POSTS
check your PCV valve and clean the IAC module and the inside of the throttle body.
that should clean up your problem.
Mar 11, 2008 at 1:16 PM
