1999 Ford F150 Hot/Cold Blending Flap
63,500 MILES • 6 CYL • 4WD • MANUAL
ALLEN MCCRAY
How to replace the heating/air conditioning blending
flap (mechanism)?
Nov 30, 2008 at 6:05 AM
DAVE H
  • 13,383 POSTS
TEMPERATURE BLEND DOOR MOTOR
Removal & Installation
Remove floor duct panel plastic push-pins, release expander clip, and remove floor duct panel. Remove right side instrument panel brace. Remove left side instrument panel brace lower nut and move brace out of the way. Remove floor duct. Disconnect temperature blend door motor connector. Remove 3 mounting screws. Pull down on blend door motor to release door motor shaft and remove blend door motor. To install, reverse removal procedure.
Nov 30, 2008 at 9:35 AM
