1999 Ford F150 heat , smells
198,000 MILES • 6 CYL • 4WD • AUTOMATIC
KART77
The heater was not blowing very hot...so... i flushed the cooling system, with the heater on while flushing.....
Every since doing this, i get a strong smell of anti-freeze, and, the windshield fogs up so bad that i have to pull over and wipe it with a cloth. I cannot find any wet areas inside the vehicle, nor can i find a leak. when i turn heater on, regardless if i have it blowing on floor, or defrost, it fogs up the windshield..... why would it do this after flushing, nad, whats the fix? it never overheats...coolant level is ok....
Feb 26, 2008 at 1:03 AM
PIGNWHISTLE
heater core is bad i think you need to let some one see it. i have the same truck and mine did same thing. it is hard to get it out so i would take it some were. good luck. i have sent my truck back 3 times.
Feb 27, 2008 at 6:58 AM
