1999 Ford F150 Fuel System
JIMINI
1999 Ford F150 6 cyl Two Wheel Drive Automatic
Fuel pump isn't working. I think the pump is located in the tank, so I'm not looking forward to having to replace it. I'm hoping you will tell me it's just a blown fuse or relay or some other easy fix.
Feb 15, 2009 at 12:24 PM
  • 75,988 POSTS
This is not an easy fix it can give the worst nightmare
You got the basic idea how it suppose to work-now if the fuse and relay turns out good-power the fuel pump directly from the battery and see what happen if it comes on check the fuel pressure-pressue okay could be an injector/s not pulsing.
Now if it still don't have power when you turn key to run-check the computer fuel pump relay controlled circuit
Feb 15, 2009 at 12:33 PM
