1999 Ford F-150 fuel pump
TIM BEASLEY
  • 1999 FORD F-150
  • V8
  • 4WD
  • 10,030 MILES
Was driving and truck died 6hrs later it started got it home and next day it would not start. It will turn over but seems like it is not getting gas I changed the fuel filter didnt help could it be the fuel pump
Saturday, August 22nd, 2009 AT 3:11 PM
DANAUTHIER
  • 156 POSTS
Your fuel pump is a possibility. First you need to check your fuel pressure. If you engine is a 4.6 litre than your fuel pressure should be between 30 - 45 psi, if it is a 5.4 than it should be 28 - 45 psi.
Check the fuel pressure and let me know what you find.
Dan
Saturday, August 22nd, 2009 AT 3:25 PM
To find out if its the fuel pump you have to perform a fuel pressure check using a guage designed for your fuel system. BTW when you turn the key to run do you hear the fuel pump come on?
Saturday, August 22nd, 2009 AT 3:26 PM
The houseman is in the house-Mr. Dan that's my man-Yea!
Saturday, August 22nd, 2009 AT 3:29 PM
