1999 Ford F150 Fuel pressure
1999 FORD F-150
220,000 MILES • V8 • 2WD • AUTOMATIC
CB963
I can start the truck just fine. But when I let up on the gas peddle, it slowly dies. Its like there is not enough fuel getting to the engine when idle. It first started more than a week ago and I thought it was bad gasoline on the last fill up. So I added a full bottle of fuel injector cleaner and topped the tank off with supreme. I didn't have any problems for a week.
Nov 25, 2008 at 2:28 AM
RACEFAN966
  • 5,029 POSTS
Ok first have you replaced the fuel filter? I would do this first if you did get bad gas or water in the fuel the filter is designed to only wick so much so it may be pluged. Let me know how it goes.
Nov 25, 2008 at 3:16 AM
