1999 Ford F150 front brakes stickin
1999 FORD F-150
146,000 MILES • 6 CYL • 4WD • AUTOMATIC
MUDDIGER
  • 6 POSTS
i have gone though the front brakes on the front of my truck i have gone though 2 sets of callabers 2 mastercylinders and 2 bosters and i have replaced the front brake lines and the front brakes are still sticking any ideals on what could be wrong with this truck
Sep 5, 2010 at 3:05 AM
KHLOW2008
  • 41,814 POSTS
Hi muddiger,
If both the front brakes are sticking after some driving, you need to check the master cylinder push rod clearance and also the clearance between the brake pedal and booster.
If there are insufficient clearance, the master cylinder piston would not return fully to allow pressure to be released when the brake pedal is not depressed.
If equipped with ABS, the modulator should be checked.
Mar 10, 2021 at 3:57 AM
MUDDIGER
  • 6 POSTS
[quote:067fe4037e="KHLow2008"]Hi muddiger,
If equipped with ABS, the modulator should be checked.[/quote:067fe4037e] ok did that and the brakes are soft now but no sticking
MUDDIGER
  • 6 POSTS
thanks for insight on this problem i did that and now the brakes are soft but no sticking
KHLOW2008
  • 41,814 POSTS
You're welcome and glad to know you have fixed the problem.
Thank you for using 2carpros and have a great day.
