I've been having some issues with my truck stuttering and bogging down while I drive. From what I can tell so far I am having a fuel delivery issue. I was wondering what the symptoms of a bad regulator would be. I hooked up a pressure gauge and took it for a drive. What I noticed is when the pressure stays in the range of 30-34 psi everything runs smooth, but when I gun it a bit the pressure jumps to 40 and the truck starts to chug up the road. This exact same thing happens when I take off from a stop. I have not taken the injectors off yet but they sound fine through all rpm ranges. I don't have any check engine lights on, and hooked up a hand held code reader though and did not get anything out of range on it. Is there something I might be missing, or is there another test I can do to pinpoint the issue. Any info would be a great help.
Thank you
Kyle
Thank you
Kyle
Aug 8, 2010 at 11:25 AM
