1990 Ford F-150 frustration
JSTELL
  • 1990 FORD F-150
Engine Mechanical problem
1990 Ford F150 V8 Two Wheel Drive Automatic
1990 Ford, 5.8 EFI, flooding, replaced injectors, replaced fuel pressure regulator, replaced map sensor, replaced climate control sensor, and truck is still flooding. Frustrated, please assist.
Sunday, May 18th, 2008 AT 4:04 PM
BMRFIXIT
  • 19,053 POSTS
Check coolant sensor
check O2 sensors
Sunday, May 18th, 2008 AT 9:46 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
Have you checked the gap on your spark plugs and the primary and secondary voltage at the coil. The resistance in the wires are a possible culprit as well.
Sunday, May 25th, 2008 AT 2:51 AM
