Where is the fan resistor located in a 1999 Ford F150
Jan 9, 2010 at 2:59 AM
✓Experienced Mechanic
Check behind the glove box on the HVAC assembly. Also, there is a relay that can also be bad. Can you describe what is happening? Does the blower motor only work on high?
Jan 11, 2010 at 2:51 AM
HALLKE
MEMBER
Low and medium do not work
High and extra high work
Jan 11, 2010 at 10:28 AM
You're right. It sounds like the resister.
Jan 11, 2010 at 11:53 AM
HALLKE
MEMBER
Is it easier to take the glove compartment out and if so how difficult is that? If not is it easily located behind the box?
Jan 11, 2010 at 11:55 PM
I can't remember exactly on the 99. It should be easy to see. There will be a plug with a few wires plugging into it and it will be on the HVAC assembly. Also, if I remember correctly, you need to remove the glove box.
