how can u tell if your catalytic converter is bad or going bad
Nov 5, 2009 at 6:28 PM
BMRFIXIT
✓Experienced Mechanic
Check engine light will let you know
as PCM is always monitoring the converter s
also some may brake apart inside and make a rattling sounds
Nov 5, 2009 at 10:11 PM
DJCARRILLO
MEMBER
[quote:5f49a9f207="BMRFIXIT"]Check engine light will let you know
also some may brake apart inside and make a rattling sounds[/quote:5f49a9f207]
Nov 6, 2009 at 7:52 AM
BMRFIXIT
Hit replay to question
type in your question or answer
and hit submit
