If I leave my battery connected it drains?
1999 FORD F-150
JAY1111
Electrical problem
1999 Ford F150 6 cyl Two Wheel Drive Manual
If I leave my battery connected it drains, I hooked up my meter and started pulling fuses. when I got to the one that killed to continuity I looked it up in the book and it said there was no fuse there. it was fuse #107 in the distribution panel under the hood. Somebody told me it could be my starter I just don't see how. please help
Apr 1, 2009 at 2:28 AM
JAMES W.
  • 2,394 POSTS
My diagrams don't show a fuse 107. Fuse #17 shows "not used". Regardless, someone may have added something aftermarket to this circuit. You'll have to trace it down and see where t goes.
Apr 1, 2009 at 2:12 PM
  • 55,224 POSTS
fuse #107 is not used so there can be a fuse there, but I can tell you have have seen the PCM power relay stick on and cause this problem, I would remove it to see if the problem disappears. Here is a guide to help as well and I have included the relay location in the images below.
https://www.2carpros.com/articles/car-battery-dead-overnight
Check out the images (below). Let us know how it goes
Aug 20, 2024 at 9:44 AM
