1999 Ford F150 coolant smell coming from a/c and heating ou
1999 FORD F-150
WOLFCLAN06
1999 Ford F150 V8 Four Wheel Drive
I can smell antifreeze coming from my ac outlets and when i turn on the ac I can see like a mist coming out. Can also see leaking of some kind from bottom of truck. I thank you in advance for any help with your knowledge you may have in this matter. Thank you
Sep 11, 2008 at 6:43 AM
BMRFIXIT
  • 19,053 POSTS
U have to start under the hood
check for coolant leak
pressure test will help identifying the leak area
if u have coolant leaking inside on the floor I would suspect heater core
Sep 11, 2008 at 7:16 AM
