1999 Ford F150 Coolant leak
260,000 MILES • V8 • 4WD • AUTOMATIC
BBESSETTE
I have a coolant leak that seems to be originating from the top rear part of the engine. Could this be a head gasket leak or is it something more intense?
Brad
Dec 7, 2007 at 9:59 AM
BLACKOP555
  • 10,386 POSTS
have you noticed white exhaust with the smell of antifreeze? if so you have a bad head gasket. you may also have a cracked or warped head due to overheating.
Dec 7, 2007 at 10:15 AM
  • 55,649 POSTS
I have seen the thermostat housing leak and the intake manifold as well. You need to use a flashlight while the cooling system is under pressure. These guides can help you find the leak.
https://www.2carpros.com/articles/car-is-leaking-coolant
and
https://www.2carpros.com/articles/radiator-pressure-test
Please go over these guides and get back to us.
Jul 17, 2024 at 10:38 AM
