1999 Ford F150 clutch
1999 FORD F-150
129,000 MILES • 6 CYL • 2WD • MANUAL
MRK1326
My 99 F150 will not go into gear (sometimes) it is not slipping once in gear. I have to turn off the truck put it into gear (goes in easy) and float the gears while driving. Is there a cluctch brake like on big trucks? What can I do to fix what ever the problem is?
Jun 23, 2010 at 1:16 AM
  • 110,244 POSTS
When you shut the engine, place it in gear, push the clutch in and start it, is the clutch working?
Jul 2, 2010 at 3:12 PM
