1999 Ford F150 BRAKE LIGHTS
89,000 MILES • 6 CYL • 2WD • MANUAL
PATA
The brake lights won't work. All other lights including the turn signals, flashers, etc work just fine. I have replaced the tail lights and fuse #6 in the power box under the hood and fuse #13 under the dash. Brake lights still won't work. Suggestions ? Thank you. Pat
Jan 9, 2009 at 1:22 PM
  • 110,248 POSTS
Pat, Check and make sure the brake light switch isn't stuck closed at the brake pedal. If it appears ok, check if there is power to it and out.
Let me know what you find.
Jan 9, 2009 at 3:49 PM
