1999 Ford F150 brake calipers not releasing
78,000 MILES • V8 • 2WD • AUTOMATIC
TADPOW
front brake calipers not releasing
left front just replaced and still the same problem. when brakes are applied and relleased they still hold a bit.
under hard braking a pull to the right is also present
Aug 6, 2008 at 1:01 PM
BLACKOP555
  • 10,386 POSTS
the pull to the right is probably because hte left side is dragging, causing the brakes to heat up and not be as efficent as the cool side.
i would check for a restricted brake line causing tha tproblem, does cracking the bleeder valve loosen up the caliper?
Aug 6, 2008 at 2:48 PM
