1999 Ford F150 Battery problem
22,000 MILES • V8 • 2WD • AUTOMATIC
K_SANDERS
Just installed new battery. When truck in drive and sitting at an idle, battery light flickers on dash. When I pull away from idle, such as a stop light, battery light goes out. It does not do this all the time. do I have a bad alternator?
May 12, 2010 at 9:48 AM
  • 75,988 POSTS
Check the alternator drive belt if okay have the alternator load tested-also check for loose connection on back of it-
May 12, 2010 at 11:16 AM
