1999 Ford F150 antifreeze leak
TKING
Smells problem
1999 Ford F150 V8 Two Wheel Drive Automatic 100.00 miles
Can smell antifreeze in the cab.can see leaking out side down the fire wall but can't see where it comming from.I was told it is the heater core can you help?
Nov 6, 2008 at 3:00 PM
IMPALASS
  • 3,112 POSTS
Hello
Yes your heater core is bad and leaking inside your cab. I can provide you with instructions on how to change it but I will need to know the specific engine size you have in liter and the 8th digit of your VIN.
So let me know if you would like the instructions.
Nov 6, 2008 at 3:11 PM
