1999 Ford F150
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
STEPHENCJ
How to replace a rear pinion seal?
how to get to the seal?
how to remove the seal ?
Dec 23, 2007 at 2:03 PM
  • 31,937 POSTS
Remove tail shaft from rear diff.
Undo pinion flange nut.
Slide off pinion.
With a seal removing tool or a large screw driver, pry out seal.
Clean housing wher seal sits.
Carefully knock in new seal, make sure it is square.
Inspect flange and if seal surface is grooved fit speedi sleeve or replace flange.
Fit flange and do up nut to torque specs,
Be carefull not to over tighten as diff may have a collapsible sleeve(pre loading for pinion bearing) and over tightening will damage bearings.
Replace tail shaft,
Check diff oil level.
Road test for noise.
Mark (mhpautos)
Dec 23, 2007 at 2:21 PM
