1999 Ford F150
1999 FORD F-150
180,000 MILES • 6 CYL • FWD • MANUAL
ASOR
clutch works fine then drive about 10 min. then try to switch gears it is very difficult to put into gear. when i pump the clutch pedal then it works to put into gear.
Jun 2, 2010 at 7:17 AM
  • 110,244 POSTS
Is there ever a chattering when you pull out? If not, it may be a bad slave cylender or if there is a chatter, the pressure plate may be weak. When they get hot, that is when you will feel the problem.
Jun 3, 2010 at 6:18 AM
