1999 Ford F-150 rear brakes pulsating for 11years.
JOHN AMARI
Brakes problem
1999 Ford F-150 6 cyl Two Wheel Drive Automatic
the rear drum brakes on my 1999 f150 always pulsate real bad. have not been able to find a mechanic to solve this problem. all four wheels have been complety done several times.new rear drums that have been turned.front disc all new.could someone please help. thank you
Oct 19, 2010 at 5:45 AM
WRENCHTECH
  • 20,760 POSTS
You could have a bent axle in the rear causing the drum to wobble. You can use a dial indicator to measure the front rotors.
Oct 19, 2010 at 6:11 AM
