1999 Ford F-150 idle
1999 FORD F-150
182,000 MILES • V8 • 4WD • AUTOMATIC
MYF150
my 1999 f-150 idles rough and even rougher in gear changed iac valve still idles rough
Oct 7, 2010 at 12:32 PM
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Oct 7, 2010 at 3:56 PM
