1998 Ford F150 will not disengauge trans lock out and no br
1998 FORD F-150
MARK SORENSEN
Electrical problem
1998 Ford F150 V8 Four Wheel Drive Automatic
I can trick it into starting in neutral but I still have no brake lights and all the fuses test good along with the switch at the pedal.
thanks
Mark S.
updated 2-10-10
Found the prob. blown fuse labled dome light on/off switch brake. the latter being the part I didn't catch for the first hour and was found when I pulled and checked every fuse.
thanks for the effort
Mark
Feb 9, 2010 at 4:44 AM
You need to get the brake lights to work-the brake switch powers the shift lock control solenoid within the shift interlock control system. also a part of the cruise control-
Feb 9, 2010 at 4:50 AM
