1998 Ford F150 Trouble codes
1998 FORD F-150
108,200 MILES • V8 • 2WD • AUTOMATIC
PAPAW2561
I get two codes, but they don't really tell me anything. P0171, P0174. One says right bank is lean, the other says, the left bank is lean.
The fuel pump is working. I just replaced the fuel filter. Where do I go from here? Is it the pressure regulator? All the injectors are working.
If I got some trash in the tank, can I blow air back trough the system to clear it, like the old days?
Thanks.....HELP,,,,
Dec 8, 2007 at 5:20 PM
Welcome to 2carpros
P0171/P0174, On many Fords, a P0171 and/or P0174 Lean Code may sometimes appear because of a bad Differential Pressure Sensor (DPFE). This sensor monitors EGR flow, and is located on the engine near the EGR valve. There are two hoses that connect the sensor to the tube that runs from the exhaust manifold to the EGR valve. The sensor misreads EGR flow and the computer increases EGR which has a leaning effect on the fuel mixture. The fix is to replace the DPFE sensor.
Dec 8, 2007 at 9:44 PM
  • 55,423 POSTS
codes P0171 and P0174 for a 1998 Ford F-150 indicate that the engine is running too lean on both banks (Bank 1 and Bank 2) so this happens when there is a vacuum leak or the MAF sensor needs to be replaced in most cases. Please go over this guide as well for more information:
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Here is a guide to help check for a vacuum leak, use when the engine is cold only:
Here is the location of the MAF so you can swap it out to see if it fixes it:
https://youtu.be/ueHWUF6F120?si=ysqAfSqZJyy-qN1W
Please go over these guides and get back to us.
Aug 2, 2024 at 3:46 AM
