1998 Ford F150 Trailer tail light plug in
JNICHOLSON3024
Electrical problem
1998 Ford F150 V8 Four Wheel Drive 165000 miles
I have a problem with a 7 prong factory installed tail light receiver for a trailer plug in. The poles for brake, left and right turn do not work. The other 4 poles do work. I've checked fuses and found a bad one but the rest seem to be OK. Could there be something else like a relay or someting that is bad?
May 14, 2010 at 3:11 AM
  • 110,248 POSTS
No to the relay. Do the signals and brake lights work on the truck? If so, then no to a fuse.
Have you taken the receiver apart and checked the wiring in?
May 15, 2010 at 4:12 PM
