1998 Ford F150 timing chain
CHARNAP731
Engine Performance problem
1998 Ford F150 6 cyl Two Wheel Drive Manual
How do you replace the timing chain from the cam to the crank?
Mar 12, 2009 at 10:56 AM
MIAMIII13
  • 40 POSTS
if you have not been a ford tech for @ least 10 years doing this particular type of timing chain replacement do not attempt this on your own. if this is the dual chain application it is next to impossible to change. it would be easierwith the alignment tool for this job but even then it will never run right again. i promise u that. worst possible design ever in an engine.u either have a good one or a bad 1 that easy. r u possitively sure its the timing chain?
May 17, 2020 at 4:30 AM
