1998 Ford F-150 Slips in forward gear but not in reverse
DALE68
  • 1998 FORD F-150
  • V8
  • 187,000 MILES
With no warning my transmission slips in forward if I rev it up enough it finally gets moving but reverse is fine. The fluid is full still redish pink and doesn't smell burnt. Any ideas
Sunday, March 14th, 2010 AT 6:28 PM
  • 109,885 POSTS
Does it slip in all gears or just certain one.
Wednesday, March 24th, 2021 AT 10:07 AM
DALE68
Ya it slips in all gears L 2 3 and OD just reverse is good.
  • 109,885 POSTS
If it is slipping in all gears, chances are it needs rebuilt. In this case (if no check engine light has come on) I think a trans tech needs to drive it. It could be a bad trans control module, but that should have set the check engine light.
