1998 Ford F150 rear drums
1998 FORD F-150
90,000 MILES • V8 • 2WD • AUTOMATIC
GOOGENHIMER
cannot get rear drums off,what is the trick
Apr 13, 2008 at 11:01 AM
  • 31,937 POSTS
Hi there,
If they are just stuck on the axle flange, give then a belt with a hammer, (wear goggles if you do this)this will shock it loose, and sometimes there is a deep lip on the in side of older drums, so you may have to back off the brake adjuster to decrease the shoe contact so the drum will slide off. This video will help
https://youtu.be/UV0kfP17Co0
Mark (mhpautos)
Apr 6, 2021 at 5:12 AM
