1998 Ford F150 rear axle
197,000 MILES • V8 • 2WD • AUTOMATIC
JERRY NOROTN
I replaced r-side rear axle and both sides bearings but there is some noise and play in axle after 1500miles. Could there have been some metal left behind that could cause this problem. I pulled the fill plug and there was a lot of metal on the magnet. If I have to replace it all again how do I prevent this next time. thanks
Jul 16, 2010 at 6:31 PM
  • 110,248 POSTS
You need to identify where the metal shavings are coming from first. Also, when the axles are out, flush everything out to make sure there is nothing left behind.
Jul 17, 2010 at 6:34 PM
