1998 Ford F150 radio
1998 FORD F-150
106,000 MILES • 6 CYL • 2WD • MANUAL
ROBERT151767
The am side of the radio has a lot of static, very irritating to listen to talk radio. Can I fix this myself? If a new radio is in order, how do I remove the radio from the dash?
Thanks, Rob
Apr 24, 2008 at 2:20 PM
MOPARNUT1393
  • 34 POSTS
its usually best to replace..... those are all solid state parts in that stereo.... have you checked you attenna wires?
you can usually find another factory stereo in the salvage yards and getting them out isnt to bad either.
on the front of the stereo there are 4 small square holes... if you go to wal-mart they have a radio removal tool thats cheap all you do is take the 4 rods and stick them in those square holes and the radio should come out if you dont want to buy the tool you can take 4 thin nails and slide them into those holes and then pull it out that way.
Apr 24, 2008 at 4:03 PM
