1998 Ford F150 pulley wobbley
1998 FORD F-150
189,000 MILES • V8 • 4WD • AUTOMATIC
SONMEL3
Can I get instructions on how to change the A/C clutch assembly.
Aug 20, 2009 at 3:00 PM
  • 31,937 POSTS
Hi there,
un plug the power wire, remove the belt, undo the nut on the shaft and with a suitable puller the clutch will with draw from the shaft, it will be a tapered shaft so you just need to move it a little to dislodge it.
mark (mhpautos)
Aug 20, 2009 at 4:34 PM
