1998 Ford F150 PROBLEM MAY BE IN SEVERAL CATEGORIES
145,783 MILES • V8 • 2WD • AUTOMATIC
FRANKIEBOY12
WHEN ACCELERATING AND THE TRANNY GOES THRU ALL THE GEARS INTO OVERDRIVE, AND I'M DRIVING AT A STEADY SPEED BETWEEN 45 AND 70 MPH, IF I GIVE IT A LITTLE GAS THE TRUCK SHUDDERS CONTINUOUSLY AS IF GOING OVER ALOT OF TRAIN TRACKS TILL I GIVE IT MORE GAS OR I EASE UP ON THE ACCELERATER. A MECHANIC INSTALLED A NEW TORQUE CONVERTER AND DID A SOFT PARTS O/H OF THE TRANNY. HE ALSO REPLACED ALL THE SPARK PLUGS AND HE FOUND A BAD COIL. I DROVE THE TRUCK FOR ABOUT 15 MILES AND THE SYMPTOMS APPEARED AGAIN. THE COMPUTER IS NOT THROWING OUT ANY FLAGS OR CODES. ANY CLUE AS TO WHAT'S WRONG?
Aug 13, 2008 at 1:44 PM
2CARPRO JACK
  • 11,533 POSTS
What is a "soft parts overhaul"? Only does it in OD at those speeds? doesnt misfire at lower speeds? still sounds like an issue with the transmission.
Aug 14, 2008 at 1:22 AM
