1998 Ford F150 mass air flow sensor
132,000 MILES • V8 • 4WD • AUTOMATIC
SLIMJONES
I just had this sensor replaced, and now the engine hesitates as the rpm increases as I increase speed from a stop. It hesitates, speeds up, hesitates again, etc., until I achieve faster speed or push the pedal to drop to a lower gear. after that there is no hesitation.
Can this be the fault of the mass air flow sensor?
Jan 30, 2010 at 11:30 AM
BLACKOP555
  • 10,386 POSTS
yes it is very likely there is a issue with the MAF sensor. either it was replaced backwards, as in example, the flow arrows staped on the sensor are not facing the proper way and it wont work. or the sensor that was put it was faulty.
Jan 31, 2010 at 6:05 AM
