1998 Ford F150 letting out the clutch
1998 FORD F-150
REXXXER25Z
Shakes or Wobbles problem
1998 Ford F150 6 cyl Two Wheel Drive Manual 189k miles
I had my clutch replaced at the same time I had a new slave cylender put in! About 9 to 10 months after the install, I started to notice that when I go to let the clutch out, the whole back end of the truck starts to shake. I have tried to change the way I let the clutch out, to no avail! I've been driving manual cars for 20 years and havent had this happen before. i hope you can help. Thank you for your help!
Aug 9, 2010 at 7:31 AM
  • 110,240 POSTS
Either the pressure plate is bad or the clutch disc is worn. Also, when the work was done, was the flywheel resurfaced or replaced?
Aug 10, 2010 at 3:31 PM
