1998 Ford F-150 ignition tumbler
MJZBUILDS
  • 1998 FORD F-150
  • V8
  • 317,000 MILES
I removed the keys from the ignition and the power was still on. I figured that the switch finally died. So I replaced it with a new one and nothing changed the power stays on.
Friday, July 11th, 2008 AT 3:45 PM
BLACKOP555
  • 10,371 POSTS
Did you replace the ignition switch or the ignition tumbler?
Friday, July 11th, 2008 AT 8:58 PM
MJZBUILDS
I replaced the keyed tumbller. The power is stuck on and the steering wheel lock doesn't work. What do I do next?
Saturday, July 12th, 2008 AT 11:41 AM
BLACKOP555
  • 10,371 POSTS
Check the ignition switch, we can go from there, could be related but morst likely are two separate problems.
Is the key just spinning in thte tumbler without tension? Or does it feel normal?
Saturday, July 12th, 2008 AT 9:05 PM
MJZBUILDS
No it does not feel normal.
I also replaced the ignition switch and nothing happened still the same.
Sunday, July 13th, 2008 AT 12:15 PM
BLACKOP555
  • 10,371 POSTS
Hmm, could be a broken control arm in the steering column causing no response from it, have that checked, and ill do some more research here.
Sunday, July 13th, 2008 AT 11:12 PM
