1998 Ford F150 ford pos
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
STEPHENHINCHEY
when my truck idols it starts to shake alil and occasionally stalls. i popped the hood and i can hear air leaking, i suspect its the vacuum hose and i think its under the intake manifold. id like to know how do i replace it?
May 13, 2010 at 8:54 AM
  • 110,248 POSTS
THere are no hoses under the intake. Are you sure it isn't the intake itself?
May 15, 2010 at 4:21 PM
STEPHENHINCHEY
yeah i traced the hose and im sure its under the intake, its the elbow of the hose that is suspect, it leads right into the intake. it looks a little weathered. any advice on how to replace the hose would be great.
May 25, 2010 at 12:25 PM
  • 110,248 POSTS
Is it the one that comes off the rear of the intake and then has a 90 degree bend?
May 25, 2010 at 3:31 PM
STEPHENHINCHEY
yes
Jun 1, 2010 at 9:47 AM
  • 110,248 POSTS
That is becoming a very common problem on these vehicles as they get older. Basically, all you need to do is R&R the part. You will most likely want to get a new hose with the 90 in it. Otherwise, you may end up with a kink in the new hose.
Let me know if it works for you.
Jun 1, 2010 at 2:33 PM
