1998 Ford F150 ford F- 150 won't start,no spark
LONNIE145
Engine Mechanical problem
1998 Ford F150 Two Wheel Drive Automatic
1998 F- 150 won't start, has fuel,seems to have
no spark?
any ideas?
Feb 3, 2010 at 10:41 PM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
Feb 3, 2010 at 10:48 PM
LONNIE145
how do i check the coil packs for fire?
Feb 3, 2010 at 11:16 PM
  • 75,988 POSTS
Disconnect sparkplug wire one at a time and ground it and crank engine over
Feb 3, 2010 at 11:29 PM
