1998 Ford F150 engin light
JANDMKILLEN
Engine Performance problem
1998 Ford F150 6 cyl Two Wheel Drive Automatic
I had the check engin light come on last week. The truck had over a hundred thousand miles. The parts place got codes andthey sad it was both oxegen sensors and said they need replaced. I can not see both going at the same time. what do I need to do to fix the truck. I feel there is somthing causing it to run lean.
Aug 22, 2008 at 9:56 AM
BMRFIXIT
  • 19,053 POSTS
need codes !!!
check for vacuum leaks
check intake manifold gasket
Aug 22, 2008 at 11:18 PM
