1998 Ford F150 Drum Brakes Lock up and pulse badly (REAR BR
190,000 MILES • V8 • 4WD • AUTOMATIC
EASTCOASTMC
Rear brakes locking up!!!
1) Replaced front and rear e-brake cables (they were rusted and bound up)
2) Replaced shoes,hardware and drums.
3) Wheel cylinders are not leaking.
STILL LOCKING UP AND PULSATING
The few mechanics looked at it are baffled...
HELP!!!
Aug 13, 2009 at 10:27 AM
2CARPRO JACK
  • 11,533 POSTS
What kind of shoes are you using? If they are reman the odds are good that the curve is incorrect causing too much shoe contact in the drum, which causes lock up.
Aug 24, 2009 at 5:19 AM
EASTCOASTMC
Thanks for the reply...
The shoes are not reman.
This was happening prior to replacing shoes, hardware, drums, e-brake cables.
eastcoastmc
Aug 24, 2009 at 5:30 AM
2CARPRO JACK
  • 11,533 POSTS
both lock up at the same time?
Aug 24, 2009 at 6:12 AM
EASTCOASTMC
yes, both sides lock up at the same time.
Aug 24, 2009 at 7:59 AM
2CARPRO JACK
  • 11,533 POSTS
Usually a pulsation in the rear indicates they are out of round (egg shaped). What brand of shoes/drums did you use? have the drums been checked for being out of round? Are the primary and secondary shoes in the correct spots? Sorry for the basic questions, this is all stuff I would check first if I had the vehicle
Aug 24, 2009 at 9:22 AM
MJR346
  • 132 POSTS
Are you having any other issues such as ABS light on or check engine light on?
If sensor on rear end has issues it will sometimes cause lock up as described. Another thing is Ford had some issues with shoes grabbing early in morning on dewey or rainy type mornings on those vehicles and was almost a characteristic.
Aug 24, 2009 at 2:07 PM
