Code P1299
190,000 MILES • V8 • 2WD • AUTOMATIC
CYNTHIA OAKLEY
The engine is overheating and I can hear water under the dash whats going on here?
Nov 19, 2008 at 12:06 PM
  • 55,691 POSTS
This indicates the engine has overheated. So first question is the radiator full? You are hearing the water under the dash because that is where the heater core is and there is probably air in the system which tells me that the radiator is low which can be because of a blown head gasket.
Here are guides to help us see whats going on.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
and
https://www.2carpros.com/articles/car-is-leaking-coolant
Cheers, Ken
Jan 21, 2018 at 7:12 AM
