1998 Ford F150 clutch
1998 FORD F-150
200,000 MILES • 6 CYL • 4WD • MANUAL
V8_S10_93
i am needing a walkthrough on how to changing the clutch and throwout bearing. the throwout bearing started making a noise when the clutch was pressed and then the next day i was stopped at a stoplight and the truck all of a sudden jumped forward and died. now the clutch doesn't seem to work and you cant get it into gear. you can turn the truck off and put it in gear and when it starts it just takes off. I would really appreciate some help because i cant afford to pay a shop to do the work. Thanks
Mar 1, 2009 at 7:16 AM
DAVE H
  • 13,384 POSTS
CLUTCH DISC, FLYWHEEL, PILOT BEARING & PRESSURE PLATE
NOTE:Replace clutch disc and pressure plate as an assembly. Replace pilot bearing only if it is damaged.
CAUTION:DO NOT use cleaners with a petroleum base or immerse pressure plate in solvent.
Removal (F150/F250 Light Duty Pickup)
Disconnect negative battery cable. Disconnect clutch master cylinder push rod. Raise and support vehicle. Remove starter. Disconnect clutch slave cylinder hydraulic line by pressing White retainer bushing with Disconnect Tool (T88T-70522-A) while pulling on line.
Remove transmission. TRANSMISSION. On 4WD vehicles, remove transfer case. See TRANSFER CASE. Check pressure plate finger height variations before removing pressure plate. If finger height variations exist, replace pressure plate. Place reference mark on pressure plate and flywheel for reassembly reference. Loosen pressure plate-to-flywheel bolts evenly until springs are expanded. Remove pressure plate and clutch disc.
Remove all but 2 flywheel bolts. Loosen last 2 bolts. Install 2 flywheel bolts into threaded holes in flywheel. Using puller, remove flywheel and then pilot bearing.
Inspection
Inspect clutch pressure plate diaphragm fingers for wear. Inspect clutch plate for oil or grease saturation, worn or loose facings, warpage, loose rivets at hub and broken springs. Also inspect for wear or rust on splines.
Using a slide caliper, measure depth to rivet heads. Minimum rivet depth is 0.012" (0.3 mm). Using a dial indicator, check clutch plate runout. Maximum clutch plate runout is 0.0276" (0.700 mm). Inspect flywheel for cracks, heat damage, wear and scoring. Machine flywheel if scored or worn. Using a dial indicator, measure flywheel runout. Maximum flywheel runout is 0.008" (0.2 mm).
Check crankshaft for misalignment and looseness. Check pilot bearing needle rollers for scoring, discoloration, wear, breakage and inadequate grease. Check rear main seal for leakage. Inspect pressure plate for burn marks, scores, flatness and ridges. Install NEW clutch plate on transmission input shaft and ensure clutch plate slides freely.
Installation
Clean pressure plate and flywheel surface with alcohol-based solvent. Pilot bearing is prelubed and does not require additional lubrication. Install pilot bearing with seal facing transmission. Using Pilot Bearing Replacer (T85T-7137-A), install pilot bearing. Adjust pressure plate. See CLUTCH PRESSURE PLATE (OFF-VEHICLE) under ADJUSTMENTS.
Using Clutch Alignment Shaft (T83T-7137-A), position clutch disc on flywheel. Position pressure plate assembly on flywheel. Align pressure plate and clutch disc with reference mark, and install retaining bolts.
Apply Threadlock/Sealer (EOAZ-19554-AA) to flywheel bolt threads. Tighten bolts evenly in a crisscross sequence. Remove clutch input shaft or clutch aligner. To complete installation, reverse removal procedure. Tighten bolts to specification. Refer to the TORQUE SPECIFICATIONS table.
Mar 1, 2009 at 8:08 AM
