1998 Ford F150 BRAKES SMOKE AND STICK WHEN HOT?
1998 FORD F-150
BERGA12
Brakes problem
1998 Ford F150 6 cyl Two Wheel Drive Automatic 220K miles
1998 F150. WHEN ITS HOT OUT THE PASSENGER BRAKE STICKS, THE WHEEL PULLS TO THE RIGHT AND IT EVENTUALLY STARTS TO SMOKE REALLY REALLY BAD AND SMELLS LIKE CALIPER. I DID CHANGE THE PADS AND THE CALIPER BUT IT STILL HEATS UP AND SMOKES..
?/????? ANY IDEAS?
May 27, 2010 at 10:43 AM
Check the brake hose could have collasped and acting as a one way way check valve if not check the ABS unit/master cylinder
May 27, 2010 at 11:47 AM
