1998 Ford F150 BRAKE VIBRATION
1998 FORD F-150
90,000 MILES • V8 • 2WD • AUTOMATIC
JIMMY1971
I HAVE REPLACED L. SPINDEL AND WHEEL BEARING. R. CALIPER AND SUPPORT BRAKET. ALL BRAKES LOOK GOOD AND NEW. THEY HAVE BEEN REPLACED. AT ABOUT 45 MPH I HIT THE BRAKES AND THE BRAKE PEDAL WILL VIBRATE AND PUSH BACK AT YOU. WHAT COULD BE THE PROBLEM OTHER THEN WHAT I HAVE DONE ALREADY? THE FASTER YOU GO THE WORSE THE VIBRATION.
Aug 28, 2010 at 5:39 AM
Sounds like a brake rotor warpage-get it miked out
Aug 29, 2010 at 1:34 AM
