HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
General
Tools
SPONSORED LINKS
1998 Ford F-150 Belt
MICASE
MEMBER
1998 FORD F-150
V8
2WD
AUTOMATIC
150 MILES
How do you change or tieten the belt? Do you need a certon tool?
Tuesday, October 14th, 2008 AT 2:58 PM
DOCFIXIT
MECHANIC
The belt is auto adj by tensioner. To replace put a wrench on bolt of the tensioner and release. Pull belt reverse
SPONSORED LINKS
Tuesday, October 14th, 2008 AT 3:05 PM
MICASE
MEMBER
Tuesday, October 14th, 2008 AT 3:37 PM
Please
login
or
register
to post a reply.
Related Tool Content
2001 Ford F-150 Tool
What Store Sells The Camshaft Lock Tool For This Vehicle?
Asked by
djjones
1 ANSWER
2001
FORD F-150
VIDEO
How to Use a Torque Wrench
Instructional repair video
1991 Ford F150 How To
How Do You Change The Lower Manifold Gaskets On A 1991 Ford F-150? Also What Tools Are Needed For This Job
Asked by
saurber
1 ANSWER
1991
FORD F-150
Blows 5 Amp Fuse To Instrument Cluster About Every 2-3...
Blows 5 Amp Fuse To Instument Cluster About Every 2-3 Trips. Happens When Moving Shift Lever From Park To Drive Or Vice Versa.
Asked by
dme73
1 IMAGE
1998
FORD F-150
Are There Fuses Or Relays I Need To Check?
No Heat, After Repairs
Asked by
bill toney
1998
FORD F-150
1998 Ford F150 Car Part Name
Brakes Problem 1998 Ford F150 6 Cyl Two Wheel Drive Automatic This Afternoon, I Remove My Front Disc And Brake Shoes. When I Pulled...
Asked by
edjard
1 ANSWER
1998
FORD F-150
VIEW MORE
SPONSORED LINKS
Engine Oil Change and Filter BMW X5
Code Read Retrieval/Clear Honda
Engine Oil Change and Filter Chevrolet
Online car repair manuals
